tonysm
Hi,
Am new here, have an Ibiza mk3 cupra, with a strange issue. Have just complete a 40k service and have replaced all the Vac lines with 2mm hose, also installed a boost gauge. All is working fine but when gunning the car when warm getting on for 5 to 5.5k RPM the engine is over reving when you change gear by about .5 to 1k as if the trottle is stuck for a sec. the boost is ok can see it from the gauge and all the lines are connected and ok. The car is standard as such, not chipped.
I have pulled the plugs out that i fitted in the service (bosch super 4's) and put back the old ones to test this morning, and the car behaved the same. But only does so when fully warmed up. Have read through the forums for a couple of days and cant see anything on this...
Also the bosch plugs i got from GSF have a 0.26 Gap, too small I think from what I have read here.
Any help would be great...
T
T
Check that none of the hoses are kinked, particularly the actuator hose.
