Im having a few issues with this. I havent started fitting them yet but I know what to do with the wiring etc, but its the bulbs.
I got the H4 bulbs for my 1.4 and they have 2 bulbs, a long one and a short one, Im guessing they have built in sidelights.
You can see the bulb on there, it has a ceramic tube on it and a metal cover bit. Should the sidelight bulbs be on the inside or outside? The ceramic tube is meant to be on the right.
Also how will I get the small block thing that the original halogen bulb pushes into out from behind the cover that clips on the back?
Any help would be greatful.
Craig.
Craig.
with them being a H4 kit. I have a black 3 prong connector, which plugs into the where the halogen bulbs usually are. Then theres a wire that goes to the ballast, and two seperate wires that plug into the ones that are coming from the ballast.
