mattyb95
Hi guys. I've started noticing a high pitched whining noise coming from the engine intermittently when washing the car. Well I say then but I guess that's the only time I hang around long enough after having driven it. I need to look into it more to see if it does it from cold or only after having driven it but just wondering if anybody else has experienced this?
I think the original poster's noise in question is the fly by wire throttle pedal system
***in layman's terms***
The throttle pedal is just a potentiometer and then at the other end of the system the butterfly valve inside the throttle body is moved by a stepper motor
This stepper motor makes a high pitched noise when it is not on the move
Or it could be your HID ballasts if you have any
So nothing to worry about? I know its not the door as it keeps going repetitively and is definitely coming from the engine area. Its possibly only if I'm using a lot of water as well. For example, had what looked like paint on the bonnet and front wing so just washed those to make sure it came off and can't say I heard it despite having literally just driven the 16 miles home from work.
