The immobilizer lives within the cluster. if you intend to fit an mfd cluster it needs to be compatible with your vehicle i.e around the same year of manufacture with the same immo.
once you have the correct cluster you will need either both pin codes for the clusters or software capable of reading and writing the immo data into the new cluster.
if you use the pins and vcds then you'll also need both keys present, the old cluster is then unusable.
if you use the immo dump then both the new and old clusters will be plug and play as you've effectively just cloned them and you can swap them around as you see fit.
the milage can be adjusted using the same software for pin code reading or the immo dumps.
