VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Thursday,03,July,2014,17:58:15:00656
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ9R004204 Mileage: 78000km/48466miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX) Labels: 03C-906-022-CAX.clb
Part No SW: 03C 906 022 AQ HW: 03C 906 022 B
Component: MED17.5.20 G 6660
Revision: D5H03--- Serial number: SEX7Z0H431E09K
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6BDE6A0C4A8760465E5-803E
1 Fault Found:
049493 - No Communication with Instrument Cluster
U0155 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 78009 km
Time Indication: 0
Date: 2000.00.00
Time: 17:55:40
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 74.0°C
Temperature: 48.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
Readiness: 0110 0101
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 74EC7170D7B9BFBE8FF-8021
4 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 49408
Count: 0
Count: 0
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 270
Count: 49408
Count: 0
Count: 0
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 2
Count: 12800
Count: 195
Count: 49152
Count: 0
Count: 0
Count: 0
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 2
Count: 12800
Count: 320
Count: 49152
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D5AA414B413AE76001-8078
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000005690780
Coding: 018C0F2F00041000431D00000000000000007F075C000000000000000000
Shop #: WSC 06403 785 00200
VCID: 336EB26C5237F886565-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 210508 022 0601
Coding: 00056208
Shop #: WSC 06403
No fault code found.
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A03 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP96GX7Z
Coding: 0012339
Shop #: WSC 06402 785 00200
VCID: 3B7E9A4C7A6730C68E5-806E
Subsystem 1 - Serial number: 6333FTS630511238
Subsystem 2 - Serial number: 6343FTS601761238
Subsystem 3 - Serial number: 6353ETS6E2KFTVNP
Subsystem 4 - Serial number: 6363ETS61HKGTVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0100
Coding: 0003042
VCID: 840CA1B0C7190F3E3FF-80D1
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 001 0010
3 Faults Found:
01426 - Controls in Steering Wheel (E221)
01750 - Multi-Function Switch in Steering Wheel (E440); Left
01751 - Multi-Function Switch in Steering Wheel(E441); Right
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 941 B
Component: KOMBIINSTRUMENT VO3 0522
Coding: 0000401
Shop #: WSC 01918 210 75632
VCID: 2C5CA9108F09A77E17F-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K085150188
Coding: E9807F060002020203
VCID: 356A8C745C43E6B6781-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0522
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000011388328
Coding: 0004784
VCID: 4084EDA01381531EDB7-8015
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 77 2301
Revision: 00H15000
VCID: 2A50AF0885FDB94EE53-807F
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F00068D0D60085F06107C80
VCID: 830EA2ACC2170806065-80D6
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000783088419
Coding: 0004784
VCID: 4182E8A4188B5A16D49-8014
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000003141130
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000003157234
Coding: 0000144
VCID: 3C7C99507F6937FE87F-8069
End ---------------------------------------------------------------------
Do you have any scans before the cluster fit? I only ask as the ABS pump coding will be on it and you can just punch it in. The other 3 will just require calibrating.
Thursday,03,July,2014,18:48:01:00656
Coding: 0000072
1 Fault Found:
U0155 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 78009 km
Time Indication: 0
Date: 2000.00.00
Time: 18:37:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 51.0°C
Voltage: 12.065 V
Revision: 00H35001
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12288
Count: 320
Count: 44800
Count: 0
Count: 0
Count: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 78009 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 2
Count: 12288
Count: 195
Count: 44544
Count: 0
Count: 0
Count: 0
1 Fault Found:
Coding: 00056208
Shop #: WSC 06403
Coding: 0012339
Coding: 0003042
3 Faults Found:
Coding: 0000401
Coding: 0004784
Revision: 00H15000
Coding: 0004784
Coding: 0000144
Coding: 0000144
See if someone with the same model as yours can do a scan of their ABS and post it up so you have a code to use. Failing that it'll be a trip to seat.
Might also require access authorisation to enter it...
Vas PC might do it but you'll need the lead as software
I can help with the engine fault code (no comms with instrument cluster), go into adaption channel 039 in the cluster and change from 0 to 1. Had the exact same problem.
I've also had the 0229 Auto-HVAC code, not on my Leon but on the Golf. Needed a new AC compressor :(
Thanks mate ill give that a go later on :)
The air con is to do with my air con pipe being split , i have anew one to go on :)
the steering controls are because i have a 2014 leon steering wheel fitted and havent wired it up as yet correctly
Hi folks, I'm considering upgrading my cluster to a second hand high line cluster. Does the immo dump you're talking about sort the immobiliser and milage on the clocks? Is it difficult to do?
I'm thinking if doing the same, only difference is my Leon is pre facelift. Glad to hear it's a simple job, I had heard some people saying it couldn't be done with a 2nd hand cluster. Did you do it yourself?
