Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
These cars have a secondare water pump that pumps water through the turbo for aprox 30s once the engine is turned off. Better that any turbo timer.
Your making it sound like if you fit a turbo timer you do away with the secondary water pump.
Its the ECU's that dont like them. Think its something to do with the ECU not wanting to run when the key is removed and wont let you lock the car ( I could be wrong though).
If TT's where necessary do you not think the likes of VW/Audi, Vauxhall, Renault etc with modern turbocharged "hot hatches" pushing good power would incorporate them into the car?
Also moderd oil is so much berrer now.
Yeh mine stays on for longer than 30secs.
Are you being serious?! TT is 100times better than a secondary water pump! A secondary water pump will pump water/coolant after the engine is swithed of if over a certain temp. Doesnt do anything with the oil though which is the important bit and will kill your turbo. You dont get them as standard due to cost and legality issues (you can imagine the lawsuits against the manufacturers). The better oil means nada, it will still cook your bearings, and the new ecus wont do anything about your oil once your engine is off.
A TT is very useful if you drive hard and then just want to get out. You might aswell just drive abit easier for the last few miles home or sit in the car for a minute or so when you get back though. Wiring up a TT doesnt seem to be very easy on mk3 cupras for some reason and not many people have them but it very important to make sure your oil is cool enough before you turn your engine off unless you dont care about your car.
TT's are all well and good, but can you alarm your car when the engine is running ? Imagine parking in a multi story and leaving the engine running for however long then having to come back and alarm the car. Personally id rather spare a minute or two and let it tick over for a while then spending however much on a turbo timer
I'm wondering when you'd be driving like a loon, kicking hell out of your car & think 'hey' I need to stop here immediately & get away from my car.
I'm trying to think of a scenario & failing.... perhaps someone can help me out?
Oh, and how have we all managed for the last 9 yrs of Ibiza's without these devices?
