i know there are a few of you out there who have changed to twin horns.
I've bought a set, and don't know how to fit them???
1) where is the original horn fitted?
2) do i need to take the bumper off??
3) or can i get to them by removing the engine tray??
Any assistance is very much appreciated
The car is a facelift 07 model 130PDi FR
Cheers......Stu
The horn is behind the lower grilles, you may need to remove the centre grille to change it (I did mine but it was so long ago I can't remember!) or you may get away with removing the NS one.
No bumper or undertray removal needed! :D
You say its easy... but removing the centre grill on a cupra bumper is a bumper-off job. Um guessing its tha same with the Facelft! Doh!
I need a new toot toot!
What horns have people fitted? Gave mine a blast when this dozy person decided they wanted to cut me up on a roundabout as they missed their junction and I was just embarrassed :redface:
Just a dual tone one i guess, i know Pasatts have then cos Muddy was baosting about his - the barsteward!
I assume most 'bigger cars' Might jst goto a scrapper and take a 12v battery :p
I've fitted twin horns from an Alhambra, they are plug and play
you only need to remove the passenger side fog light surround (pop it off)
you will find it a bit of a tight fit, I know I did :p :p
i tell u wot guys....if u think the ibiza's horns are bad....u should hear my gf's corsa's! its dreadful! proper suits her being a girl tho!:doh:
Yep bumper off job on the cupra the horn will be positioned in the same place (n/s lower point on front pannel) but u might be able to worm your way around not taking the bumper off.
only takes 5 minuites to take her off and you can give the rads good wash down
the horn on my cupra is embarrasing how am i suppost to cause road rage with a horn like that!
I must admit mine sounds a bit "gay"! Ive seen sparco do one but id like a more manly "fook off you c*nt im coming through"!
think yourselves lucky.i sometimes have to drive our 14 tonne tanker.its got a single tone car horn on it.
its amazingly gay :redface:
I quite like the claxon ones demon tweeks sell.sounds very monte carlo rally :D
mine sounds so bad ive bought a audi a3 deeper tone horn with same connectors as mine on it just gotta swap them over!
one is high and one is low but they tend to freeze up in the winter and make funny farting noises when you press then :p
extremely loud tho
