andy_wpo
29
Hy guys,
I'm just curious how bad it is??Guess is not a normal think and something is wrong with my engine.(BKD)
First clip the engine is cold
Second one is after 10 km and hot engine (90 degrees ) - lot of smoke :O
Third one is with hot engine off - again,tone of smoke :(
And the 4th is the expansion tank open , water level up a bit (there is no oil in expension tank,oil cooler was changed)
So how bad it is???Should i take in consideration an engine rebuild???
Tnks,sry for so many vids :)
The oil cap creates a seal when the engine is running. Unscrewing it with the engine running takes the pressure away probably not the best. Smoke is probably going to be the hot air meeting the outside.
