My Koni FSD's & Eibach springs have improved the ride no end!
I found the factory SEAT Sport suspension a bit too harsh for my liking, so fitted the above & haven't been disappointed.
It gives a plush ride at slower speeds but firms up at speed, so it's nice & compliant.
I have the same Koni FSD/Eibach Pro setup as Jon and it is a great improvement over the standard suspension; but I would say that if you want your car to look like it's lowered, then you may not be happy, as the lowering is subtle, only around 25mm. This does have the advantage of not scraping the underside on every speed bump though!
This is when they were first fitted.
They have settled a little more since then, but have no recent pics.
Thanks Jon, would you say that the ride height is now nicely even between front and back, and how long did it take to fully settle.
jontdi - how much would i be spending to get the same set up as you?
Also would it class as a modification for insurance purposes?
That seems OK; it cost me about £750 nearly 2 years ago from BigBoysToys, but you are saving on the VAT; one of the benefits of the credit crunch!I have a quote from JKM for
FSDs are £353.73 plus VAT
EIbach Springs are £114.23 plus VAT
Total cost - £538.15
Fitting is £150.00 plus VAT - £172.50 inc VAT
£710.65 all in.
Yes, it is fairly even, just slightly higher at the rear as most cars are to compensate for passengers and or luggage.Hows your ride height at the rear? Similar to Jon TDis, just trying to canvas as muck opinion as possible before I buy.
One word. Never buy only springs for your car, when trying to get better handling and etc.. Always seek whole setup, which means shocks+springs. Whole setup will match perfectly together to gain good results.
