ive done 98600
owned it since 37k
only thing to have gone (apart from wear and tear) was the clutch 'I' burnt out trying to get out a snow drift lol
plus another 30 or so since taking the photo :)
03 SLCR 102,000 miles, the cars 2nd owner.
Since I've had it, around 40k, it's had the following:
Replacement lower engine due to Conrod malfunction peiced the block (3 months after purchase)
Ignition Coil
Several Spark Coils
Several Sets of Tyres
Fuel Pump
3 Fuel Filters
Split Coolant Pipe
Now needs some sensors and values... I've a HELP thread on here to source and fix.
Another issue.....
04 Plate Cupra Tdi PD150, Had it since 2006, now covered 112,000 miles
Unfortunately i have had all the common faults!
1) Turbo blown - sticky vane syndrome
2) Cam Followers wore out and took cam with it
3) Power steering pump failed and wiped out the rack with contamination
4) ECU internal power fault - Replacement ECU
5) On-going glow plug loom fault - have the spare loom just not fitted it.
6) Dual Mass flywheel replaced at 106k - nursed it along for a while with the rattle until i hear it on smoke test at the MOT, where the testing asked if i was sure i wanted him to carry on!!!!
7) Current hot start issues and slight turbo hesitation at 3000 rpm - trying to diagnose......
its still standard but only getting about 38-40 mpg.
Full Service history
Love it though! considering getting it mapped, but a little nervous considering the mileage
Just been advised i'll need a reconditioned gearbox soon! got a bearing squeal :cry:
