ballin
Hi,
I have diagnosed a problem with the top mounts, when you turn the steering very slowly you can see the spring catching and then pinging around, which sends a small noise and vibration back through the steering.
How is best to replace the top mount/bearing? Can I just undo the top and replace, or do I need to remove the strut?
If the strut needs removing, what is the best way?
Thanks!
Thanks!
Not that I'm an expert, but I'm fairly competent.
