Sam@xtreme Full Member Mar 8, 2006 87 0 Hertfordshire www.xtrememotorsport.co.uk Jul 12, 2007 #1 My car is running really lean and need to turn the fueling up, any ideas? What AFR do you run?? Cheers
StanTheMan Guest Jul 12, 2007 #2 Sam@xtreme said: My car is running really lean and need to turn the fueling up, any ideas? What AFR do you run?? Cheers Click to expand... Forget about increasing it, whats causing the lean out would be more important.
Cupra_Jeff Active Member Mar 8, 2005 126 0 Kent Jul 12, 2007 #3 Mine is running a wideband and doesn't go above around 11.8 - 12.0 on wide open throttle.... mainly around 11.0 - 11.5 range
ibizacupra Jack-RIP my little Friend Jul 25, 2001 31,333 18 glos.uk Jul 12, 2007 #4 Sam@xtreme said: My car is running really lean and need to turn the fueling up, any ideas? What AFR do you run?? Cheers Click to expand... most lean running is caused by under reading MAF. how are you judging yours is lean? 12:1 is usually best power, but common to run a bit richer for cooling issues.
