Will this cable also charge my IPod through the 3.5mm jack as my Leon doesn't appear to have the USB option?
Cheers.......Mad Jock
You can't charge an iPod through the 3.5mm jack I'm afraid. If you don't have a USB jack I'm not sure that the above cable will work for you at all to be honest.
Doh! Thought that would be too good to be true. Any idea what the 3.5 jack will do then as I thought it would still play my ipod throught the Aux but perhaps have no steering wheel control. Anly changes would have to be done through the ipod itself.
I think you can just use a cheapo 3.5mm to 3.5mm lead. No need for the USB bit and you'd have to control it all from the iPod.
quick update, since upgrading to IOS5 i dont get the "this device is not compatible" type message when i plugged it in.
Does the BMW lead allow you to chnage tracks from the headunit itself or just the ipod?
Guys in my Leon mk2 facelift I have the iPod and usb sockets under the stereo can I use the bmw cable for iPod integration
Has anyone tried connecting the I phone 5 with the BMW cable using a 30 pin - lightning crossover?? If so, does it work??
yep! Does make it hat bit longer though so doesnt sit as neat as id like in wee dish area, but works a treat though!
D
