I think i have fixed my leaking door seals!!
ChrisJ
Lemon
Feb 2, 2007
314
APD Vag - Near Holton Heath
My front passengers door has been leaking, if you open the door after its been raining you get a cascade of water on your feet!:no: :no: or even worse you drive off and if you havent opened the door the water simpley floodes!! across the mat!!:-o :-o
But i think i have cured the problem today, i removed the black rubber seal along the bottom of the door and cleaned under it and the seal its self, as this was thick with gubgey crud!! so im hoping this will have fixed the problem:rolleyes:
DarkSeat
113
Birmingham
Hi mate,
I have the same problem on the drivers side, when you open the door you get a little waterfall. PLease let me know if this works as i will try it myself when it finally stops raining.
DS:clap:
ChrisJ
Lemon
Feb 2, 2007
314
Hmmm yea its kinda fixed, i have made the issue better but not quite fixed,:confused: it dosent run in over night now but it still pours off of the sill when you open the door after its rained FFS!!
i think im gunna hafto take the trim off on saturday oh joy!! no doubt the usual plastic clips will break off :doh:
