JackFR2010
Hello,
This is my first post, but i have used this site many times in the past for SEAT knowledge. Im not sure if anything like this has been posted before, i have looked but found nothing, so here it goes.
I currently own a 2010 Ibiza FR, 1.4 TSI, I am looking at converting it to a Cupra (sort of). There are a few things i need some answers too.
1) Spoiler. Does anyone recommend or know of a spoiler which will fit the FR model, its not made of cheap nasty material and would not need any modifications in order for it too fit. I can only find a few cheap ones on eBay, and am dubious to whether they will fit.
2) Xenon headlights? Is it possible to simply change the bulbs? If so, any recommendations on bulbs that looked good and shine bright!!! If the whole unit needs changing in order to suit, again, what has worked well for you and where is a good/reliable place to buy.
3) The big one!!! I want to upgrade the exhaust system. I currently have the two tail pipes on the passenger side of the car. I want a center pipe! I understand that this could get quite costly. I have been told that the entire back bumper needs changing. Is this true, or can i simply get away with changing the valence (black plastic above the tail pipe) to one with a center hole. In regards to the actual exhaust system, is the whole thing different, thus requiring new pipes and brackets, or does the end-pipe just need changing to one that finishes in the center.
Im not after any loud, sporty exhausts, just a standard cupra version.
Any help is appreciated.
The rear bumper to take the centre exhaust, the part number is 6J3071061. Expect to pay £300-£400 for this supplied in primer. Then you need a couple of brackets etc plus the actual exhaust bits.
The rear bootlid spoiler you're best off sticking with the official SEAT part, it'll be around £180 supplied in primer so expect to pay a body shop something like £80 to paint and fit.
Speak to Dave at SERE Motors on here, he can definitely supply the spoiler and can look into the bumper parts to see if they're still available and what exactly you'll need.
No idea mate, ask Dave at SERE but they'll be expensive and dealers are usually reluctant to supply demons if the car didn't already come with them. Probably be best to buy some white coloured lamps.
