Nov 26, 2026
hello everyone i am desperately looking for a front grill for my ibiza cupra 1.4tsi 2014 (facelift), the one where the seat and cupra badge is located. it has been 2 months of trial and error even from seat direct parts.They advertised the correct grill but sent a different one stating it is the same but does not even fit my car . As you can imagine this has been a long and annoying process for me so any help in the right direction is appreciated. The files attached are what i ordered vs what i have received twice now!!!
Hi,
If you don't mind sharing your VIN with me via a private message, I can look it up on the parts catalog.
Regards,
Serdar
Reactions: Yenula
It seems the issue is less about finding a grille and more about identifying the correct part in the first place. I'd start by checking the exact OEM part number against the VIN, then compare it with the number on the grille itself and the mounting points. The different front-end versions of the Ibiza 6J can look very similar, but that doesn't necessarily mean the parts are interchangeable.
Reactions: Yenula
thank you for the reply, the original part number i found is
6JL853651C9B9 and i have ordered two grills based on this. yet the ones i have recived look different and do not fit the car. The grills were ordered from original vag parts dealers.
