Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Not really relevant to he OP's post, but could you point me to where the law states it has to be within 3% of the original fitment?To be within the law the outside rolling circumference needs to be within 3% of the original fitment.
The lower the profile the more feel you get of the road, however, if you run on softer sidewall tyres the ride will become softer with less feel and sometimes less noise depending on tread block design, however, this of course also has downsides when it comes to balance, also a harder compound will offer less feedback than that of a soft grippy compound..
The OP has stated ^ it's not down to requiring more comfort..
Taller sidewalls will only provide a softer wall strength if remaining with the exact same tire manufacture and model of tyre.
The OP could fit a different brand which offers a softer sidewall and in addition could change to 215/45 17" which offers a slightly taller wall and remains within the law as it's within 3% of original, however, it would then be good advise to check with ones insurance company beforehand to see if they class this as a modification..
Perhaps I worded it wrong, it's not the ride that's harsh more the feel of the low profile tyre, can a tyre be fitted with a slightly taller side wall ?
Quite the opposite, the OP said, quote " Needs it to be a bit comfier, it's just a mile muncher." and corrected his initial posting in as much as he was aiming to achieve this only by changing tyres/tyre sizes and not suspension.
Sent from my C55 using Tapatalk
The frst link is Australia and the second link mentions that they don't reccomend and not that there are legal implications.
Your speedo will be inaccurate but I have never heard of it being against the law to change by more than 3%
Sent from my SM-G900F using Tapatalk
