Ibiza FT 1.8 intercooler
Zealot
7
Hello,
I have seat ibiza FR 2007 1.8T BJX . I'm searching the best for my buck intercooler upgrade.
What you will say about these thicker custom SMIC that are everywhere ? Are these SMIC for Golf4 gti are the same like mine.
I like this bolt on easy to replace solution. Is it any good ?
I know most of you would probably say "go for seat sport FMIC" , but they are 5 times more expensive.
After intercooler upgrade , I'm going for custom remap at 1.1 - 1.0 BAR .
Thanks.
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
Take a look at Forge, they do their own Seat Sport style FMIC, I know from experience they are very good bits of kit.
Zealot
7
Is this DIRENZA side intercooler suitable for ibiza mk4 FR 1.8T ? The shame looks like the same .
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
I've no experience of it, but if you're going for a remap you really want to be upgrading to a decent FMIC, these cars do run very hot so the more cooling you can get the better you'll be. Don't waste money buying a better SMIC because you'll only end up buying a FMIC further down the line. Your money so it's up to you but I'd spend the extra and do it right first time around.
Sent from my G3 using Tuppytalk
Zealot
7
Ok, I'm going for universal FMIC ? What will be the best volume/ size intercooler ? We are talking for 1.1 bar peak boost remap.
Marcus_550
138
Stockton On Tees
Just get a seat sport one or a copy off ebay and make your own pipe work, can get a seat sport copy with 70mm end tanks for 150 quid, same type as my cupra one but bigger end tanks, would of thought u will have to butcher your front bumper which ever fmic u buy
Zealot
7
This sounds reasonable. there will need pipes. Where the map sensor should be positioned - into the inlet or outlet ?
Zealot
7
if ur on a budget could try one of these, no idea if its any good but can't see it being worse than a side mount
I'm going for this cooler.
Could you help me gather the necessary pipes and silicone connectors .
I would like to make it the same .
Look at the picture, I think it would be helpful .
ttp://i.ebayimg.com/00/s/NzI3WDEwMDA=/z/kEYAAOSwNSxU5Htc/$_57.JPG
What angles are these
