Hi all,
I have a Mk4 Ibiza PD160 Cupra which has done 96,000 miles and is currently on a set of coilovers that the previous owner fitted, approximately 20,000 miles ago. I think they are made by GAZ.
I like the look of the car with the lower stance but I don't like the extremely stiff ride.
Having never driven a standard Cupra, I do not know if they are much softer. Perhaps I should test drive a stock Cupra and see the difference?
The car sometimes feels like its shaking itself apart, and there are some rattling noises coming from underneath which are getting worse all the time. I think it is probably just the bushes need replacing as when the car was MOT'd I asked him to take a look and he said everything seems fine.
My car has a SACHS clutch and is remapped to 200 BHP and 360 lb ft / 500 Nm. Does more power mean I should have stiffer suspension to cope or doesn't it matter?
The car came with the standard shocks and springs that were removed from the car when the coilovers were fitted so I still have these.
My question is what would be the best course of action to make the ride smoother?
Should I fit the stock springs and dampers back on even tho they may have done almost 80k miles and make the car look very high?
Should I get a new set, from SEAT or wherever sell them?
Should I get a new set of coilovers that someone could recommend that give the best ride comfort?
Or just stick with what I have and just put 215/45 tyres on? I've already put these on the rear but haven't noticed much of a difference in the ride at the rear, wondered if it would make more difference having the extra 5% profile on the front.
I guess I should first get some new bushes or at least determine what is causing all the rattling underneath, but I was going to take this opportunity to sort the suspension out at the same time.
If anyone has any suggestions, or knows of a make of aftermarket suspension that they can recommend, it would be much appreciated.
Cheers,
Andrew.
Cheers,
Andrew.
