Injectors
j5ive
60
20
Hello,has anyone changed the injectors themselves if so is it an easy job???
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,219
1,106
Kent
Extremely easy then in that case. Just unbolt the fuel rail from the inlet manifold and the whole lot will pull out of the injector cups.
The injectors are then held onto the rail with clips that simply slide off.
Sent from my SM-G986B using Tapatalk
j5ive
60
20
Brilliant, thank you for your help should be able to that myself then.
j5ive
60
20
Hello, thanks for your help the other day, have a question for you, if I replace the injectors myself will they programming????
