Trying to install a new alternator, the old one gave up.
Got a new one, but the mounting points are a little wider. I presume the threaded inserts on the regulator side will slide over to meet the mount as the bolt is being tightened, but the inserts seem very stiff. Do they need to be oiled, or will they begin to move OK when the tension is high enough?
Also, the new alternator doesn't have the little 8mm post for clipping on the heavy cable. Any easy way of getting it off the old alternator and transferring?
