if it's the 2k plus one then it's not to bad
where the door pull is there is a piece of plastic on the inside which has some indentations on it this clips off than you can carefully unclip the whole door switch assy so you should be able to get to the switches....
i think...........
i think...........
It is a 2001 model - will have a look in day light ... Cheers
