cakes
can anyone advise me on how to take out my instrument clocks on my 2001 alhambra 1.9tdi..............
Im not sure if its similar to the Arosa but,if it is its along the following lines.
There are 4 screws in the dashboard surround that holds the cluster in. The cover slides out and then there should be a further 4 screws. The cluster then comes out and there is a blue connector at the back that when unclipped will remove the cluster.
I just about managed to do it on the Arosa without removing the steering wheel but, it was quite fiddly and very frustrating.
May I ask why your removing it ?
im looking to change the dash bulbs to blue so its the same as the vw sharan.....
wherebouts is the four screws located on dash ???????
Im only going by what I know on an arosa or Golf. If it is the same they are inside the instrument cluster cover.
if it's the later one it will more likely be pcb mounted smd ? led's i think they call em, not an easy bulb swap sadly
There are 2 on the bottom somewhere ???
cheers guys,,, but if they are leds, i dont think i"ll bother.......
anyone know where i can get genuine mudflaps for my alhambra??????
