Intermittent Engine Juddering
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Before I go to my SEAT dealer can any one offer any possibilities to the following problem.
While I let my car warm up on the drive way the rev's drop down then pick up again.
While accelerating + plus also lifting off the power the eninge starts Juddering.
Also this only happens now and then maybe one or twice a month.
The only mod I had done last was the intake manifold replaced with a poished one which was done by my dealer. (never had this problem before then)
If the coil pack was starting to go would the problem happen all the time :confused:
Could it be the throttle body when I had the manifold done.
Any info on what it could be would be helpful
Thanks in advance
Steven
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Coil pack would show up under load, rather than just randomly.
Is there a possibility of an air leak on one of the gaskets / lines on the inlet manifold?
Vag-Com check is the way forward really.
*Separately, any chance of replacing the missing pictures in your Reader's Rides thread?
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Yeah I will pop down to the dealer next weekend for a check up.
But I bet the car will behave :rolleyes: but it should have a fault code for them to check.
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Well the dealer was no help as there was no fault codes.
I bought a nice after market MAF sensor housing complete with sensor, better than the Bosch one plus also changed my Induction kit.
The Car is running perfectly now! :D
I used to stick up for K&N but it is true their filters are over oiled. It killed my MAF in under 4000 miles :(
Any way sorted ;)
