Intermittent problem with starting. P0322
Edward81
44
Hi all,
My Leon 1.8 Mk1 has recently developed an intermittent fault whereby its starts absolutely fine when cold but if I were to go on a short journey, then switch the engine off and come back a few minutes later the engine won't start. The starter motor is fine, fuel pump all ok. If I leave it for an hour or so and go back it will start.
Recorded a code P0322 last time it had the issue.
Crank shaft sensor issue?
Would welcome your views. If the crank shaft sensor is it easy to locate and change?
Thanks. (y)
Rich.T
1,609
932
Hi all,
Thanks. (y)
Is it fixed?
What was it in the end?
