Ipod Nano 7th Gen Help
Proudy
Hi,
I have an Ipod Nano 7th gen and cannot for the life of me get this to connect to my media system with bluetooth - and with it being a lightning adapter i cannot connect it straight to the glovebox input - any idea how to get the bluetooth working or what cable would i need to get to connect this up?
Jul 29, 2013
859
Essex
Hi I just set the car to scan and then stayed on the bluetooth connection screen of the ipod to ok it.
It works well with a lightning afaptor but you need a new cable to pull the album art etc.
Proudy
Must be a problem with the Nano as it just stays scanning never finds the car
i turn it to visible and then when i get out and come back in the Bluetooth of the car has set itself back to hidden is that right?
keithjeb
187
The bluetooth in the car is only set to visible for the first 90 s or so after its turned on. That said, once its paired it should stay paired.
Proudy
No luck with pairing it to the Nano they just cant see each other i know the nano is only a2dp wonder if that is the issue as i also have my phone connected?
either way i am just going to get a lightning to 30 pin adapter that should sort everything
Any idea where to get the red cable to allow album art?
Jul 29, 2013
859
Essex
I often have my ipod and phone both bluetoothed in. Phone is calls only and ipod is media only. I got my red cable from the dealer
Proudy
do you have a nano or regular ipod? i think its the Nano's being sh*te
AJ
250
Is that the one that provides video play through the infotainment system?
Yes Madduffyx that's right, plays videos from your itunes library for compatible devices on the media screen whilst the car is stationery (you can unlock this with vcds so works even when moving).
I use my wife's old iPhone 4 as an ipod and video playback works but I bought the cable predominantly for album artwork for the music though but video playback is a nice additional feature to have if I'm sat around waiting for people :)
madduffyx
348
Cheers AJ,
Very tempted to get one! Any idea what changing to coding you need to make to unlock it via the VCD's? I've got the cable but only made a few changes to the car so far.
AJ
250
Cheers AJ,
I haven't done this myself but remember seeing it as an option on the German VCDS mods site. I have pasted the link to it below:
Link
But having just read it in more detail it seems that you cannot enable it using VCDS afterall but need to use a different system called VCP.
Sorry about that, I assumed as it was there it was done by vcds.
