Nov 4, 2012
509
Callington Cornwall
I got my activation on vcds-lite yesterday so started to play today. I had one fault code that was a fuse so was easy. Here is my boost log i am on stage one does this seem right?
Code:
 ,Group A:,'115,,,,Group B:,'003,,,,Group C:, Not Running
,,Engine Speed,Engine Load,Charge Pressure,Charge Pressure,,Engine Speed,Intake Air Mass,Throttle Drive,Ignition,,,,,
,TIME,,,(specified Value),(actual Value),TIME,,,Angle Sensor 1,Timing Angle,TIME,,,,
Marker,STAMP, /min,%, mbar, mbar,STAMP, /min, g/s,%, °ATDC,STAMP,,,,
,0.00,1800,21.8,980.0,990.0,0.40,1760,8.08,5.1,18.8,,,,,
,0.80,1760,22.6,980.0,990.0,1.29,1400,3.64,1.6,23.3,,,,,
,1.71,1360,48.1,980.0,990.0,2.21,1400,13.42,9.4,15.0,,,,,
,2.61,1400,48.9,980.0,1010.0,3.00,1440,12.53,8.6,17.3,,,,,
,3.40,1440,44.4,980.0,1010.0,3.82,1440,12.31,8.2,17.3,,,,,
,4.22,1480,42.9,980.0,1010.0,4.62,1480,17.19,12.2,18.0,,,,,
,5.02,1520,55.6,980.0,1020.0,5.42,1520,12.36,8.2,18.0,,,,,
,5.83,1560,77.4,1590.0,1050.0,6.23,1600,26.75,91.4,16.5,,,,,
,6.63,1640,85.0,1840.0,1150.0,7.13,1720,29.97,98.8,12.0,,,,,
,7.54,1800,91.0,2020.0,1230.0,7.94,1880,35.28,99.6,13.5,,,,,
,8.34,1920,100.0,2130.0,1320.0,8.74,2000,43.25,100.0,11.3,,,,,
,9.14,2080,115.0,2170.0,1460.0,9.54,2160,53.44,100.0,11.3,,,,,
,9.96,2280,128.6,2180.0,1610.0,10.36,2360,62.97,100.0,10.5,,,,,
,10.76,2480,139.1,2190.0,1750.0,11.15,2560,72.03,99.6,9.8,,,,,
,11.55,2680,148.9,2200.0,1890.0,11.95,2800,85.83,99.6,7.5,,,,,
,12.37,2880,163.9,2210.0,2070.0,12.77,3040,104.75,100.0,5.3,,,,,
,13.17,3160,183.5,2170.0,2250.0,13.57,3320,115.36,99.6,6.8,,,,,
,13.97,3440,184.2,2080.0,2250.0,14.37,3560,122.33,100.0,6.0,,,,,
,14.78,3720,180.5,2070.0,2240.0,15.28,3880,129.89,100.0,8.3,,,,,
,15.68,4000,175.2,2090.0,2200.0,16.08,4120,137.39,100.0,9.8,,,,,
,16.49,4280,172.2,2050.0,2190.0,16.89,4400,141.67,100.0,10.5,,,,,
,17.31,4520,170.7,2010.0,2140.0,17.80,4640,151.08,100.0,10.5,,,,,
,18.20,4800,165.4,1950.0,2080.0,18.60,4880,154.03,99.6,12.0,,,,,
,19.02,5000,163.2,1900.0,2040.0,19.51,5120,156.94,100.0,12.0,,,,,
,19.91,5240,158.6,1870.0,2000.0,20.41,5320,159.92,100.0,9.0,,,,,
,20.82,5440,156.4,1840.0,1930.0,21.21,5520,158.69,100.0,9.8,,,,,
,21.62,5600,153.4,1830.0,1920.0,22.02,5680,164.92,99.2,9.0,,,,,
,22.42,5760,149.6,1800.0,1850.0,22.84,5840,168.08,100.0,8.3,,,,,
,23.33,5920,143.6,1780.0,1770.0,23.73,6000,162.81,99.6,11.3,,,,,
,24.13,6080,141.4,1780.0,1770.0,24.64,6160,162.81,100.0,11.3,,,,,
,25.04,6200,138.3,1780.0,1730.0,25.54,6280,165.94,100.0,15.8,,,,,
,25.95,6280,9.8,980.0,1250.0,26.45,6200,13.31,7.5,15.0,,,,,
,26.85,6080,12.0,980.0,1040.0,27.25,6040,11.56,8.6,13.5,,,,,
,27.65,6000,12.0,980.0,1020.0,28.05,5880,12.56,8.6,12.8,,,,,
,28.45,5760,12.0,980.0,1020.0,28.86,5720,13.00,9.0,12.0,,,,,
,29.26,5640,12.0,980.0,1030.0,29.66,5560,13.58,9.4,11.3,,,,,
,30.06,5480,12.0,980.0,1030.0,30.57,5360,12.44,9.0,9.0,,,,,
,30.97,5240,12.0,980.0,1040.0,31.37,5160,12.72,8.6,6.8,,,,,
,31.77,5080,12.0,980.0,1040.0,32.28,4960,12.42,8.6,4.5,,,,,
Cant seem to get the logs to look right :confused:
Code:
	Group A:	'115				Group B:	'003
		Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Engine Speed	Intake Air Mass	Throttle Drive	Ignition
	TIME			(specified Value)	(actual Value)	TIME			Angle Sensor 1	Timing Angle
Marker	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	 g/s	%	 °ATDC
	0	1800	21.8	980	990	0.4	1760	8.08	5.1	18.8
	0.8	1760	22.6	980	990	1.29	1400	3.64	1.6	23.3
	1.71	1360	48.1	980	990	2.21	1400	13.42	9.4	15
	2.61	1400	48.9	980	1010	3	1440	12.53	8.6	17.3
	3.4	1440	44.4	980	1010	3.82	1440	12.31	8.2	17.3
	4.22	1480	42.9	980	1010	4.62	1480	17.19	12.2	18
	5.02	1520	55.6	980	1020	5.42	1520	12.36	8.2	18
	5.83	1560	77.4	1590	1050	6.23	1600	26.75	91.4	16.5
	6.63	1640	85	1840	1150	7.13	1720	29.97	98.8	12
	7.54	1800	91	2020	1230	7.94	1880	35.28	99.6	13.5
	8.34	1920	100	2130	1320	8.74	2000	43.25	100	11.3
	9.14	2080	115	2170	1460	9.54	2160	53.44	100	11.3
	9.96	2280	128.6	2180	1610	10.36	2360	62.97	100	10.5
	10.76	2480	139.1	2190	1750	11.15	2560	72.03	99.6	9.8
	11.55	2680	148.9	2200	1890	11.95	2800	85.83	99.6	7.5
	12.37	2880	163.9	2210	2070	12.77	3040	104.75	100	5.3
	13.17	3160	183.5	2170	2250	13.57	3320	115.36	99.6	6.8
	13.97	3440	184.2	2080	2250	14.37	3560	122.33	100	6
	14.78	3720	180.5	2070	2240	15.28	3880	129.89	100	8.3
	15.68	4000	175.2	2090	2200	16.08	4120	137.39	100	9.8
	16.49	4280	172.2	2050	2190	16.89	4400	141.67	100	10.5
	17.31	4520	170.7	2010	2140	17.8	4640	151.08	100	10.5
	18.2	4800	165.4	1950	2080	18.6	4880	154.03	99.6	12
	19.02	5000	163.2	1900	2040	19.51	5120	156.94	100	12
	19.91	5240	158.6	1870	2000	20.41	5320	159.92	100	9
	20.82	5440	156.4	1840	1930	21.21	5520	158.69	100	9.8
	21.62	5600	153.4	1830	1920	22.02	5680	164.92	99.2	9
	22.42	5760	149.6	1800	1850	22.84	5840	168.08	100	8.3
	23.33	5920	143.6	1780	1770	23.73	6000	162.81	99.6	11.3
	24.13	6080	141.4	1780	1770	24.64	6160	162.81	100	11.3
	25.04	6200	138.3	1780	1730	25.54	6280	165.94	100	15.8
	25.95	6280	9.8	980	1250	26.45	6200	13.31	7.5	15
	26.85	6080	12	980	1040	27.25	6040	11.56	8.6	13.5
	27.65	6000	12	980	1020	28.05	5880	12.56	8.6	12.8
	28.45	5760	12	980	1020	28.86	5720	13	9	12
	29.26	5640	12	980	1030	29.66	5560	13.58	9.4	11.3
	30.06	5480	12	980	1030	30.57	5360	12.44	9	9
	30.97	5240	12	980	1040	31.37	5160	12.72	8.6	6.8
	31.77	5080	12	980	1040	32.28	4960	12.42	8.6	4.5
Not too clued up on the 1.8t but turbo seems very laggy low down. Then overboosts higher up
Looking at the log i feel it is laggy up till 3500 revs or so but in the car up till then you can hear the turbo spinning up and then feel it kick in. The car to drive in fantastic pulls very well compared to before remap.
nd-photo.nl That was the best MAF value i have had i normally get around 165 so about 207 :). Also been waiting for you too pop up thanks to you i fixed my anti hijack due to a fuse cant find the thread now so will just add rep here :)
Na i havent yet it is on the list had to do some boring things like MOT, lambda sensors but now that is out the way next will be TIP, FMIC, Blueflame full system, silicone coolant and turbo pipes, Liquid gauge then of course stage 2 :)
