Is my car a lemon or are 92 faults normal from OBDevelen?
jeeeefff
67
8
I've just brought a OBD11 pro out of interest as my recently purchased 2021 Seat Leon FR EVO 1.0tsi has had quite a bit of issues.
My initial aim was to find out the OCU version to see if it's due a firmware update in hope to rectify SOS, pop clicks and sat nav issues so I can bring it up at a possible future SEAT service.
However I was a bit shocked to see all these faults and wanted to know if this is normal or should I consider returning the car and not go through all the hassle or if this was the norm for these cars.
I'll have a deeper drive into these error codes in detail but wanted to know if its worth clearing them to see if they resurface and see it they were just old issues or leave as is for future reference.
Thanks for any advice and help on the matter.
jeeeefff
67
8
After a bit more investigation on my part, running some searches on passive errors and from what I understand, clearing all those errors via OBDeleven app seems perfectly safe, in doing so I've reduced the errors down to 4 Red errors, mainly to see if the passive ones I've seen before and have documented happy again.
I'll slowly look for the passive issues should they fire up again.
According to my OBD11, should this be of major concern?
01 Engine
System description: R3 1.0l TFS
Software number: 05C906032AF
Software version: 1700
Hardware number: 05C907394C
Hardware version: H03
ODX name: EV_ECM10TFS03005C906032AF
ODX version: 002006
Trouble codes:
U044700 - Invalid Data Received From Serial Data Gateway Module "A"
static
Date: 2025-04-10 00:08:00
Mileage: 23644 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 2156.75 1/min
Normed load value: 0.0 %
Vehicle speed: 74 km/h
Coolant temperature: 90 °C
Intake air temperature: 18 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.304 V
Dynamic environmental data: 209628F40400F40E7944CD27105852000044600BA144DD0001109C21AB201AFFFB201E0005F411203D9F00002A0737D144D00000028D0188202F0D8B
I've seen this from an Audi forum, will compare to see if they are similar:
https://www.audiworld.com/forums/audi-a5-s5-rs-5-219/u044700-invalid-data-received-gateway-3044980/
jeeeefff
67
8
This is the log before I cleared the error codes but doing some quick looks at the passives I've seen some known fixes i.e. the window one being holding down 10s, then holding up 10s.
This car does high mileage discrepancy but I'm hoping its mainly down to major user input error and OBD11 mileage check paints it more inline with what it says on my dashboard but i'm happy for any advice should it might have been tempered with. It certainly doesnt look like a car thats done 81754 miles condition wise, inside in out. Very happy for advice on tips and if its even possible for me to correct this record if its legit and correct.
OBDeleven data log
Date: 2025-04-09 23:30
VIN: VSSZZZKLZNR004459
Car: Seat Leon
Year: 2022
Engine: DLAA
Mileage: 23638 KM
01 Engine
ODX version: 002006
Long coding: 0119001223240D0870180000000000000000000000000000
Trouble codes:
static
U350100 - Control Module Input Power "A" Circuit Low
Intermittent
Intermittent
Intermittent
U041600 - Invalid Data Received From Vehicle Dynamics Control Module
Intermittent
03 Brakes
System description: ESC
Software number: 5WA614517BJ
Software version: 0131
Hardware number: 5WA614517N
Hardware version: H13
Serial number: 61471000000974
ODX name: EV_Brake1ESCEPBMQB37W
ODX version: 013055
Long coding: 34042C9822204470527B900509CC61862DB458F042D067C0219CA231018FF100001C38
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
jeeeefff
67
8
08 Air Conditioning
System description: Climatronic
Software number: 5WA907727AD
Software version: 0440
Hardware number: 5WA907727AD
Hardware version: H02
Serial number: --------------------
ODX name: EV_ACClimaBHBVW38X
ODX version: 005069
Long coding: 000100010011120010000000101011110000112100200000000000000000
Trouble codes:
U101100 - Supply voltage Voltage too low
Intermittent
U140000 - Function restriction due to insufficient voltage
Intermittent
U112100 - Databus missing message
Intermittent
B10CD00 - Function limitation due to energy management
Intermittent
09 Central Electrics
System description: BCM37w_M1
Software number: 5WA937086M
Software version: 0174
Hardware number: 5WA937086M
Hardware version: 026
Serial number: BXJ53F23062194061467
ODX name: EV_BCM37w
ODX version: 007001
Trouble codes:
C107E54 - Headlight No basic setting
static
B201B00 - Program monitoring
static
13 Adaptive Cruise Control
System description: ACC Bosch MQB
Software number: 5WA907572B
Software version: 0395
Hardware number: 5WA907572
Hardware version: H20
ODX name: EV_FRONTRADARBOSCHVW380
ODX version: 004017
Long coding: 02030015400740451247400000400004AE4020000000000000000000000000
Trouble codes:
Intermittent
Intermittent
Intermittent
U112200 - Databus implausible message
Intermittent
U112300 - Databus error value received
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
15 Airbag
System description: VW40Airbag
Software number: 1EA959655ED
Software version: 0177
Hardware number: 1EA959655ED
Hardware version: 010
Serial number: W319GyE04D1
ODX name: EV_AirbaVW40ALVVW38X
ODX version: 001012
Long coding: 88CC008000C0C000000000000000000051540000205400004000F68000930065
Trouble codes:
B1671F0 - Function limitation/status display of front pass. airbag due to undervoltage
Intermittent
Intermittent
B130487 - Left front seat belt tensioner control module missing message
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
17 Dashboard
System description: KOMBI
Software number: 5FA920790B
Software version: 5340
Hardware number: 5FA920790B
Hardware version: 220
ODX name: EV_DashBoardVDDMQB37W
ODX version: 003033
Long coding: 24A400006B900600018062032000080800300800
Trouble codes:
U105400 - Information electronics control module 1 No Communication
Intermittent
Intermittent
Intermittent
U14FE00 - Secure Onboard Communication Signature inspection failed
Intermittent
19 Gateway
System description: GW2020 High
Software number: 5WA907530G
Software version: 7097
Hardware number: 5WA907530G
Hardware version: 756
Serial number: 77104905002117103426
ODX name: EV_GatewMQB2020
ODX version: 005011
Long coding: 0000808D0F00000000000000012303115101610000000100030100000001010000000000000000000000000000000000
Trouble codes:
Intermittent
U123100 - Ethernet databus branch 6 No communication
static
U164200 - Ethernet Notrufmodul keine Kommunikation
Intermittent
U164500 - Ethernet Steuergerät für Informationselektronik 1 keine Kommunikation
Intermittent
U105200 - Generator No Communication
static
B1A5100 - Generator malfunction
Intermittent
B1802F1 - NV-Energy management Alarm triggered
Intermittent
P30DE00 - Voltage drop via generator line too large
Intermittent
Intermittent
U111100 - Function limitation due to missing message
Intermittent
Intermittent
B184C00 - Release active
Intermittent
Intermittent
23 Brake Boost
System description: EBKV
Software number: 5WA909059K
Software version: 0307
Hardware number: 3Q0909059C
Hardware version: H09
Serial number: BPA08502062101304157
ODX name: EV_BrakeBoostG2BoschVW37W
ODX version: 016028
Long coding: 1002C540730000CE39E79C73000049922449922400
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
2B Steering Column Lock
System description: ELV-MQBB
Software number: 2Q0905861B
Software version: 0040
Hardware number: 2Q0905861B
Serial number: 21000167462013
ODX name: EV_ELVMarqMQBA0
ODX version: 002004
Long coding: 0000000000000000
Trouble codes:
No trouble codes found
42 Driver Door
System description: TSG FS
Software number: 5Q4959593P
Software version: 0912
Hardware number: 5Q4959593P
Hardware version: 011
Serial number: 0000443431754
ODX name: EV_DCU2DriveSideMAXHCONT
ODX version: 001005
Long coding: 00351020D001020000001000
Trouble codes:
B148754 - Motor for window regulator No basic setting
static
44 Steering Assistance
System description: BASGEN1MQB37
Software number: 5WA907144G
Software version: 1040
Hardware number: 5WA907144C
Hardware version: 102
Serial number: 00356927
ODX name: EV_SteerAssisBASGEN1MQB37
ODX version: 007046
Long coding: 0000000000000001000102010100010000000101010101
Trouble codes:
Intermittent
static
U140A00 - Terminal 30 Open circuit
Intermittent
B1168F2 - Steering angle sensor no initialization
Intermittent
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959592P
Hardware number: 5Q4959592P
Serial number: 0000443010800
ODX name: EV_DCU2PasseSideMAXHCONT
ODX version: 001005
Long coding: 00351020DC01020000001000
Trouble codes:
Intermittent
5F Multimedia
System description: MU-O-ND-EU
Software number: 5FA035862K
Software version: 1969
Hardware number: 5FA035862
Hardware version: H56
Serial number: WG8LGM15062100010116
ODX name: EV_MUOIMQB37w
ODX version: 001002
Long coding: 43800008000000000000000000000000000000000000000000
Trouble codes:
B201A00 - Checking software version management
static
U138F00 - Clock synchronization failure
Intermittent
U111000 - Function restriction due to communication interruption
Intermittent
Intermittent
jeeeefff
67
8
75 Telematics
System description: OCU3HMQB37W
Software number: 5WA035284C
Software version: 0135
Hardware number: 5WA035284C
Hardware version: H12
Serial number: 0000000106VIEY981444
ODX name: EV_OCU3HMQB37W81444
ODX version: 002012
Long coding: 043800009068A8009005460061402607
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
76 Parking Assistance
System description: PLA 12 Kanal
Software number: 5WA919298B
Software version: 0578
Hardware number: 5WA919298
Hardware version: H05
Serial number: 00000606219456030787
ODX name: EV_EPHBO2CVW3800000
ODX version: 002028
Long coding: 8300022001
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
A5 Driver Assistance
System description: MQB MFK 3.0
Software number: 5WA980653C
Software version: 3301
Hardware number: 5WA980653
Hardware version: H06
Serial number: E5783070821167000663
ODX name: EV_MFK3ValeoMQB
ODX version: 005050
Long coding: 000309082148C040509E08800020000001018000000000000000000000000000
Trouble codes:
Intermittent
Intermittent
B7 Start System Interface
System description: Kessy IOBOX
Software number: 5WA959436H
Software version: 0722
Hardware number: 5WA959436H
Hardware version: 100
ODX name: EV_Kessy37w
ODX version: 004023
Trouble codes:
BB Rear Left Door
Trouble codes:
BC Rear Right Door
Trouble codes:
D6 LED Module Left
System description: LED1L
Software number: 992941571AE
Software version: 9202
Hardware number: 992941571A
Hardware version: H08
ODX name: EV_LLPGen3LKEBODPO68X
ODX version: 001003
Trouble codes:
Intermittent
D7 LED Module Right
System description: LED1R
ODX name: EV_LLPGen3RKEBODPO68X
ODX version: 001003
Trouble codes:
Intermittent
leonmax96
28
7
The norm has been to not have any errors anywhere.
In my experience VAG cars, 2020 and onwards, tend not to follow this ideal.
My 2021 Leon shows lots of databus missing message, databus invalid message entries as well.
Some Audi A4 I recently checked: something regarding Ethernet.
All this in various control units, they randomly come back after clearing, without any noticeably issue.
In your case, it looks like battery was low or disconnected.
Check which errors come back after clearing.
Reactions: WozzaB and jeeeefff
jeeeefff
67
8
thanks for chiming in @leonmax96, yes this is how I see it with my limited experience with older cars. Still a learning curve. After doing more digging I think passive errors are fine to clear but will keep tabs if they keep coming back.
I've tried 3 times last night to clear errors and once again just now. It seems like I keep getting the same 7 red faults after each drive upon clearing. Will try a 4th time to be sure and post here what they are shortly
jeeeefff
67
8
I was getting the same 7 red errors, I attempted to clear just now, battery seems green and fine according to the ODBeleven VAG app. After Clearing just now it did warn of a much longer read time, saying hrs as it was attempting to scan 233 things, I did let it sit for 15 mins but was nearing the end of my break. I will let it run the whole way through when home, is this normal? my previous clears last night didn't seem to result in doing a full scan that long.
I does say no faulty control units but just show up as red with fault codes and seems same thing each time I do clear the codes
a pic of it scanning 233 things:
will past the report shortly if it helps
jeeeefff
67
8
OBDeleven data log
Date: 2025-04-10 13:04
Car: Seat Leon
Year: 2022
Body type: Hatchback
Engine: DLAA
Mileage: 23654 KM
01 Engine
ODX version: 002006
Trouble codes:
static
Mileage: 23644 km
Priority: 2
03 Brakes
ODX version: 013055
Trouble codes:
Intermittent
Date: 2025-04-10 00:08:01
Mileage: 23644 km
Priority: 5
Malfunction frequency counter: 2
Unlearning counter: 39
Vehlicle_speed: 72.5 km/h
Resolution Mileage: 514 m
Voltage_value_KL.30_ESC_V: 14.0 V
LWS_comparison: completed successfully
Comparison_yaw_rate_sensor: completed successfully
Comparison_transverse_accleration: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_pressure_sensor: completed successfully
Postrun_activ: not active
Wake up CAN: not active
Wake up EPB: not active
Internal_failure_code: 28
---: 00024000080D8008808480807E0000400000084004
08 Air Conditioning
ODX version: 005069
Trouble codes:
jeeeefff
67
8
ODX name: EV_BCM37w
ODX version: 007001
Trouble codes:
static
Date: 2025-04-09 23:32:13
Mileage: 23638 km
Priority: 4
Unlearning counter: 40
Terminal 15 status: On
Terminal 50 status: Off
Engine running: Off
Status of brake lamp switch, discrete: Off
Brake lamp switch via CAN, status: Off
Voltage: 12.3 V
Outside air temperature: 10.0 °C
Light switch position: Automatic
static
Mileage: 23638 km
Priority: 6
Engine running: Off
Voltage: 12.3 V
ODX version: 004017
Trouble codes:
15 Airbag
ODX version: 001012
Trouble codes:
17 Dashboard
ODX version: 003033
Trouble codes:
Intermittent
Date: 2025-04-10 12:25:48
Mileage: 23649 km
Priority: 6
Malfunction frequency counter: 3
Unlearning counter: 166
Intermittent
Mileage: 23649 km
Priority: 6
Intermittent
Mileage: 23649 km
Priority: 6
jeeeefff
67
8
19 Gateway
ODX version: 005011
Trouble codes:
Intermittent
Date: 2025-04-10 00:15:20
Mileage: 23647 km
Priority: 4
static
Date: 2025-04-09 23:32:22
Mileage: 23638 km
Priority: 4
Malfunction frequency counter: 93
23 Brake Boost
ODX version: 016028
Trouble codes:
ODX version: 002004
Trouble codes:
42 Driver Door
ODX version: 001005
Trouble codes:
static
Date: 2025-04-09 23:32:24
Mileage: 23638 km
Priority: 5
Unlearning counter: 123
ODX version: 007046
Trouble codes:
52 Passenger Door
ODX version: 001005
Trouble codes:
5F Multimedia
ODX version: 001002
Trouble codes:
75 Telematics
ODX version: 002012
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
ODX version: 002028
Trouble codes:
ODX version: 005050
Trouble codes:
ODX version: 004023
Trouble codes:
BB Rear Left Door
Trouble codes:
BC Rear Right Door
Trouble codes:
D6 LED Module Left
ODX version: 001003
Trouble codes:
D7 LED Module Right
ODX version: 001003
Trouble codes:
jeeeefff
67
8
That's a little more reassuring to know if that's the norm, Thanks for letting me know @cairus. I am keen to keep the car and wasn't sure about how safe it was long term as I'm not only driving myself but family too.
So those red errors aren't something I should stress over and consider taking to a SEAT garage for? I'll try to let it run the longer scan later tonight.
jeeeefff
67
8
The question is, what errors are left after deletion?
ah good shout. I will find out soon after work when I have more time to allow the full scan to run, I think the app warn it could take hrs. I will try though
jeeeefff
67
8
Back again, this is the report after clearing all error codes, I've removed things that say 'No trouble codes found' and only posted the trouble code parts in hope it makes it easier to see. Im going to cross-check with older logs to see if its always the same thing, for now it looks that way. Only this time I'm seeing more null things in 75 Telematics:
01 Engine
Trouble codes:
static
Mileage: 23644 km
Priority: 2
03 Brakes
Trouble codes:
Intermittent
Mileage: 23644 km
Priority: 5
Trouble codes:
static
Mileage: 23638 km
Priority: 4
Engine running: Off
Voltage: 12.3 V
static
Mileage: 23638 km
Priority: 6
Engine running: Off
Voltage: 12.3 V
17 Dashboard
Trouble codes:
Intermittent
Mileage: 23649 km
Priority: 6
Intermittent
Mileage: 23649 km
Priority: 6
Intermittent
Mileage: 23649 km
Priority: 6
19 Gateway
Trouble codes:
Intermittent
Mileage: 23647 km
Priority: 4
static
Mileage: 23638 km
Priority: 4
42 Driver Door
Trouble codes:
static
Mileage: 23638 km
Priority: 5
75 Telematics
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
jeeeefff
67
8
Can confirm it is all identical to the report log I made at 1:04pm earlier today.
However a bit different to my reading yesterday mid night:
OBDeleven data log
Car: Seat Leon
Year: 2022
Engine: DLAA
Mileage: 23638 KM
01 Engine
Trouble codes:
static
Intermittent
Intermittent
Intermittent
Intermittent
03 Brakes
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
08 Air Conditioning
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Trouble codes:
static
static
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
15 Airbag
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
17 Dashboard
Trouble codes:
Intermittent
Intermittent
Intermittent
Intermittent
19 Gateway
Trouble codes:
Intermittent
static
Intermittent
Intermittent
static
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
23 Brake Boost
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
42 Driver Door
Trouble codes:
static
Trouble codes:
Intermittent
static
Intermittent
Intermittent
52 Passenger Door
Trouble codes:
Intermittent
5F Multimedia
Trouble codes:
static
Intermittent
Intermittent
Intermittent
75 Telematics
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
null - Unknown
Intermittent
Trouble codes:
Intermittent
Intermittent
D6 LED Module Left
Trouble codes:
Intermittent
D7 LED Module Right
Trouble codes:
Intermittent
and being this after clearing all error codes and doing another scan:
OBDeleven data log
Date: 2025-04-10 00:54
Car: Seat Leon
Year: 2022
Mileage: 23638 KM
01 Engine
Trouble codes:
static
Mileage: 23644 km
Priority: 2
cairus
1,591
555
OK, I wouldn't ignore some of these errors anymore. The car drives without the warning light active?
Reactions: jeeeefff
jeeeefff
67
8
Hi Cairus, Thanks for the wise warning.
That's right, no yellow lights on the dashboard or even when looking for car alerts on the touchscreen unit, I was trying to look for the section for warning alerts but assumed because there is non I couldn't find it, nothing popped up even short drive:
The only warnings I do get are intermintant, seem to happen when using andriod play for navigating, sound pops, map freeze, SOS yellow warning lights. This has happened once so far on short errand runs and 4 times now on longer 30+ min drives. The info unit did randomly shut off too once, then boote back up. Apart from these issues, no other warnings both on the dash or in the info screen. Operates normal too.
jeeeefff
67
8
Just making a note of errors prior to clearing all codes, just car on, not engine, keeping only the error parts:
11th April 4:53pm before wipe VSSZZZKLZNR004459 Seat Leon
OBDeleven data log
Date: 2025-04-11 17:54
Car: Seat Leon
Year: 2022
Engine: DLAA
Mileage: 23654 KM
01 Engine
Trouble codes:
static
Mileage: 23644 km
Priority: 2
03 Brakes
Trouble codes:
Intermittent
Mileage: 23644 km
Priority: 5
Unlearning counter: 38
Trouble codes:
static
Mileage: 23638 km
Priority: 4
Engine running: Off
Voltage: 12.3 V
static
Mileage: 23638 km
Priority: 6
Engine running: Off
Voltage: 12.3 V
17 Dashboard
ODX version: 003033
Trouble codes:
Intermittent
Mileage: 23649 km
Priority: 6
Intermittent
Mileage: 23649 km
Priority: 6
Intermittent
Mileage: 23649 km
Priority: 6
19 Gateway
ODX version: 005011
Trouble codes:
Intermittent
Mileage: 23647 km
Priority: 4
Intermittent
Mileage: 23638 km
Priority: 4
Malfunction frequency counter: 96
42 Driver Door
Trouble codes:
static
Mileage: 23638 km
Priority: 5
75 Telematics
Trouble codes:
null - Unknown
Intermittent
null - Unknown
Intermittent
