Jetex cat-back
Aug 29, 2010
588
suffolk
went to put on my jetex cat back today where it joins to the cat there is an inch gap it sits on the pipe but doesn't cover up the the lines for it it's a standard downpipe & cat could i just weld a another onto the centre section to get it to go over them?
Any help appreciated as my standard exhaust is blowing a fair bit.
tashacupra
Next up "twin scroll"
Jul 26, 2007
303
suffolk
You should have been supplied with a small transition tube as the jetex cat back tube is slightly diffrent size to the stock DP/Cat. This is how mine is anyway, i dont run my center section any more as i have a non res section, and custom DP so i have the center section laying in the garage with the transition tube still in it iirc, i'll get a pic when i can.
Cheers Tasha.
tashacupra
Jul 26, 2007
303
suffolk
Tashacupra where abouts In Suffolk are you
Oulton broad, although you won't see the ibiza about if your local as it's been off the road for quite some time now whilst my other half complet's a BT conversion on it, I have a mk2 facelift Leon now so have pritty much given the ibiza to my Bf to play with as he has just sold his last project.
