LEE_05
84
been looking into getting a cone filter these seem to be the best ones are they hard to fit ? and what would i need to fit it ? is it a case of removing the airbox and clamping this one in place ? has anyone had any problems with them ?
i have searched jetex cone filter guide couldent find anything.
Piece of piss to fit, really is easy. Take old airbox off, fit this in its place. Can either bolt stright to maf, or do what most people on here have done, including myself, and get a alloy joiner and silicone joiner to space it closer to the wing
must.try.harder
i have seen that thread but still carnt workout if a still need to buy a bit fo silcone hose like samco ect to fit it or does it come with everything you need ? and whats the best price for them.
The filter will fix right onto the MAF housing, however it has been known that an air filter will flow better if given an extension for the air to straighten out in before it hits the MAF housing. The added benefit of spacing it out is that you move the filter to a cooler part of the engine bay. You may need a 45º silicone bend though.
so i just buy the filter then ? were is the best place to get one ? think i will try just the filter and get a extension when i can afford it unless they are cheap enough.
Bill @ Badger5 on this site mate. Done my jetex 07003 (70mm) for £38 delivered.
You need 70mm for Leon Cupra, or 80mm for Leon Cupra R, with the latter being slightly more
mines a fr but would think its the same as an lc do you need any clip ect to put it on.
Just a jubilee clip which comes with it. But as said above, invest in a 70mm alloy joiner and 700 silicone joiner off ebay, got both off ebay for around £12 posted. A few people on here have made different mounts up to stop the maf from moving about whilst driving too
You will also need a small breather filter for the sai
have you got the link to them on ebay coz want to make sure i get the right one. also whats this small breather filter for the sai ?
sorry for been stupid but when you say pop the filter on the end of it do you meen the jetex cone filter or the small breather one and is that what side i need 28mm yeah ?
cheers bud you have been rele helpfull so them ebay links are the rite size one ect ?
Yep. 70mm connections. So you would connect the silicone joiner to the maf, then the metal joiner, then the filter ;)
still dont no witch model number filter to go for ? witch would be best for my fr few people have went for the 80mm and put 70mm reducer on.
