Right folks
Bit of an update-
Since the last post on here I've done the following-
Fitted AutoTech HPFP internals
Modified the MTC kit so the fuel trims are as close to stock as poss
Oil & Filter change (now running Millers Nano Drive 5w 40 CFS)
Changed diverter valve for a Rev G one
New cam follower fitted
Also I have been to R-T.e.c.h for stage 2+ mapping..... Very impressed with the map Niki Gower has done for me..... My cars now a very capable hot hatch with 345 Bhp & 330 ftlb's on tap
The day I had the map done it was 28 degrees.... Inlet temp were as you can imagine higher than usual.
There's still a bit more to be had from the car yet (power wise). I'm still on the stock clutch and intercooler so niki didn't want to go mad with the map.
Next changes will be- remove a/c and also get a S3 cooler
Also I'll be putting a stronger clutch in, once there done it's back to R-T.e.c.h for niki to work his magic again.
