So what your saying wilko's is that the intake manifold/TB isn't a restriction on a 18g?
hey bill ,didn't say that your throttle body/intake manifold mod would not do the extra power,i'm sure it does ,all i was interested in was seeing some results.In evoland we don't touch the intake manifold/throttle body till well over 500bhp as it isn't the bottleneck.Cams/pulleys are bread and butter for evo's. Dynojet's in my opinion overead immensly,i'd only trust dyno dynamics which read slightly lower than mustang dyno's(remember them bill).Either way like you said same dyno should show gains if run in the same way.I've seen some wild claims in the us so i tend to be a bit scepticle.
what size is the 1.8t throttle body? On evo's it's 60mm and can be ported to 65mm and if you port the stock intake manifold it will give you around 8whp.
Norris reckons you need at least gt35 to start bothering with TB's and Intake manifolds,so thats 550bhp+ In testing on a 600bhp car the best gain seen with a 80mm TB and intake was about 30-40bhp and the same in torque some actually lost power to stock!!
