kazzz25 Active Member Jul 17, 2025 56 2 Feb 12, 2026 #1 Hi everyone 1.4 2014. Car judders when moving off just on the clutch, if I give it gas it's fine. Any ideas? Thanks
SuperV8 Active Member May 30, 2019 2,172 1,199 Feb 13, 2026 #2 manual or dsg? Is it only on the first few starts in the morning - or juddering all the time? Reactions: Mr Pig
Valentin98 Active Member Jan 4, 2025 10 5 Feb 13, 2026 #3 Same engine with manual transmission, I have the same problem, even when giving gas it jolts, when the car is very hot it gets worse.
Mr Pig Active Member Jun 17, 2015 2,997 1,161 Feb 14, 2026 #4 My car will sometimes do that fulling out of the drive but when it warms up it's fine. Are you sure it's the clutch and not wheelspin? Reactions: Valentin98
kazzz25 Active Member Jul 17, 2025 56 2 Feb 15, 2026 #5 SuperV8 said: manual or dsg? Is it only on the first few starts in the morning - or juddering all the time? Click to expand... Manual All the time. Its done about 115k.
kazzz25 Active Member Jul 17, 2025 56 2 Feb 15, 2026 #6 Mr Pig said: My car will sometimes do that fulling out of the drive but when it warms up it's fine. Are you sure it's the clutch and not wheelspin? Click to expand... It's defo not wheelspin. I'm talking about just lifting off with the clutch slowly
kazzz25 Active Member Jul 17, 2025 56 2 Feb 15, 2026 #7 Valentin98 said: Same engine with manual transmission, I have the same problem, even when giving gas it jolts, when the car is very hot it gets worse. Click to expand... Did you figure out what it is?
Valentin98 Active Member Jan 4, 2025 10 5 Feb 15, 2026 #8 kazzz25 said: Did you figure out what it is? Click to expand... Unfortunately I still don't know what it could be, I'm still investigating the coils, injectors, carbon deposits, flywheel and clutch.
kazzz25 Active Member Jul 17, 2025 56 2 Jun 28, 2026 #9 Valentin98 said: Unfortunately I still don't know what it could be, I'm still investigating the coils, injectors, carbon deposits, flywheel and clutch. Click to expand... Did you get anywhere with this?
