Hi guys, i've noticed a lumpy idle on my 2000 1.9 tdi leon. I noticed that the little rail that sits on the glowplugs the fourth one had melted, I have replaced that rail with one from a scrappy however its still jumping. It will go from 800rpm to 1000rmp and back down until warm. I'm replacing the glow plugs tomarrow to see if that could be the issue. I also noticed that the little black lever attached to the EGR valve moves in time with the jumping? Whenever i hold it and stop it moving the car idles fine. I also read the codes for the car and i'm constantly getting code P1250 - Fuel level too low. Can anyone shine any light on the issue. Also just to add the idle doesn't change when i press the depress the clutch pedal.
