Oct 17, 2006
893
Walthamstow
1st, i assume there is a separate horn for the alarm as mine doesnt go off any more...it went off once and made a very low noise and faded away. but yet my normal horn works fine..
i believe the alarm horn is under the bumper (drivers side), how easy is it to change?
2nd, is there any way you can change just the colour of the two needles for the speedometer and rev counter.. as it would stand out better then the red on red...
3rd, is it possible that a crack in the vacume pipes can throw up loads of different error codes (dont have them to hand)
lastly, N75 vavle, for luv nor money coudl i see it, i know where the temp sensor is and its near there but couldnt find it..and when i do find it, how do i know which on it is?
sorry for the multiple questions & feedback appreciated
1 duno, didnt think so
2 very unlikely
3 it could do, sometimes little things can make the car throw a wobbley, but at same time lots of people have leaks from the vac hoses and no fault code ever appears
4 the n75 is between the turbo intake pipe (big black rubber hose) and the metal charge pipe over the engine bay. it has 3 small vac hoses connected to it. on the underside theres a part number, and the last letter designates what valve it is. C or F are stock valves
for the 1st question you most likely have an alarm speaker/horn attached - best to speak to seat dealer on that
for the second question yes it can be done as my bruvs done it on his mondeo but no idea on how to do it for the beefa, just like changing to the lockwood dials and simply changing it
3rd i have no idea im agreeing with acid on this one lol
