Check paint work for swirls if they have polished it post delivery to the dealership
If no car mats, ask them to throw some in
Check they have supplied the right amount of delivery fuel, usually half tank right?
While Bluetooth isn't visible as a module, make sure you can pair your phone rather going home and find it out it doesn't exist or doesn't work
Make sure you have all your books/paperwork before leaving
Besides the wheel alignment, can't you have them carry a complimentary vehicle checkpoint after 1000 miles?
What is the auto wiper thing you mentioned and gauge stage?
Good luck with the collection
Same thing, many names. Needle sweep, cluster check, gauge stage, gauge celebration etc.Ah right, gauge stage... Otherwise known as a needle sweep right?
Also is the vcds the same cable as an audi?
One quick thing I done when I first got my boc was take out the centre silencer from my stock exhaust. Gives it a little purr when idle and driving. Just a cheap little mod while u get a miltek
Cant really do that as if I upgrade the exhaust it has to be a complete one just to be able to return the car to full stock exhaust if I have any engine issues etc. Or if the centre silencer is just a bit that can be removed from original exhaust without destroying/cutting the original pipes it would be ok to do.
If all you want is sound just remove the rear seats and you'll hear the exhaust 5 times louder (in car), no mod, no cost.
Bear in mind if you do wish to change to a Milltek, the oem system needs to be cut off.
They weren't stupid - it's for ease of fitment and to reduce cost. It's fitted as one piece and then the rear suspension/beam is fitted over it.
OEM exhaust sounds pretty nice with the seats down, but all you'll hear initially is the soundaktor.
