rogers
rogers
Jan 8, 2006
999
bridgend, south wales
before we start did tyr a search couldnt find the anwser and need to be 100%]
right then guys im been looking for a k03s turbo for a while and had a emails offering me a turbo suppused to be paying for it tommorow so just want to clear it up
he says its a unsilenced version? heard of that?
8 blades?
the code is K03-053
the bit that has worried me is that i stubled accross this site and found a few codes so can people in the know just clear up is this a definate k03s turbo not k03!
http://www.not2fast.com/turbo/maps/
you can definately get either an unsilenced or silenced k03s i know that much...
Not sure about the part number.. from that link though it would look like a normal k03 ?? Hopefully that link is just wrong though ?
thats the things i clearly stated in the add i wanted a k03s so hopefully its just a bit of confusion, because he didnt know much about it as it was in his work and he starts back tommorow so im hoping hes wrong
I know I've searched the forum before and found a thread with pics comparing the two and I'm sure if you post a pic of yours up someone will soon be able to tell you exactly what it is.
Come on rogers, found this in about 5 seconds of searching...
8 blades opposed to 12 on tip,
Tip is 2ml bigger than K04
Compressor housing is 39.5ml opposed to 37ml
K03s Turbos have 0052/0053 in the serial number and they usually are 704D/704S/704T
Larger main vein and larger contiunation
ARX, AUM, AWV, AUQ - K03s turbo
kkk-052 , or 053 or 058 = k03s
Must have ended the auction early as it was on there last night.
Hopefully it wasnt the one rogers is buying as the picture in the auction was definatly only a normal k03 as it had 12 blades not 8
