K04 001 turbo
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Thanks for all of the help guys is it actually worth me fitting the turbo if its the k04-001 as im all ready running the k03s on my leon cupra all i actually need is a couple of gaskits and the 4bar fpr an im done for the bits and bobs got the injectors manifold oil and water lines :shrug: thanks again
If you have a k03s already then in a word...no
Bigbhp18t
IMO the k04-001 upg worth doing as an upgrade from a k03 or to replace a worn k03s, just to get that extra 10-15bhp and substained boost.
There is a noticable power delivery with the k04-001 and k03s, The k04-001 needs to be spooling high when shifting from 2nd to 3rd and to 4th or else it will bog down quite bad and feel flat, its a turbo that like higher revs. in other word it can be a very laggy turbo when driven in the wrong manner.
Where with the k03s-052 which spools up and come on to song a lot faster not matter where your shifting point is.
But if your thinking of comming from a good k03s then it is not worth the money.
Ben
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
yes....so my point is, the earlier turbo fitted to the 210 audi S3 (k04-001) will fit the k03 manifold?
sorry where have you got your facts from , the k04 001 , was not fitted to early s3 , k04 001 won't fit a k04 manifold it will fit a k03 , k04 001 is a slight upgrade of the k03s , the s3 /lcr/tt bam are all running k04 02 series turbo's i had a 1999 s3 and remove the turbo it was exactly the same as the k04 023 i got now for my k04 build
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
if you want to go bigher turbo all depends and your budget and what you want to acheive in terms of power v driveability , if you got deep pockets you can go big turbo gt28/30/35 but be mindful you have to do work to internals and might need stronger clutch but these turbos aren't the best imo if you want as a daily drive to shops laggy compared to k03s , you can go k03s hybrid route also which great for gains and remain quick spool
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
The standard turbo is capable of 240bhp & 270lb/ft..
All you need is a high flow down pipe, Forge TIP, open cone filter and a uprated intercooler + stage 2 map..
Henk80
Oh, but it can do more dan 240/250 BHP.
Mine does 260.
Unfortunately I can't post the dyno result because I'm below the 15 post count.
Damoegan
Oct 15, 2007
8,993
Newcastle
There are lots of people on here that have made ~200g/s on a standard k03s (with logs to prove it)..
I have seen as mutch as 193g/s and consistantly used to log 185g/s....
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
Mine does 260.
sorry from my experience having had 4 k03s powered cars and many mates with k03s powered cars and experience with many tuners and comments from 95% of tuners won't flow pass around 190 g/s accurate g/s anyway i've seen what your saying your car is flowing 210 g/s when the maf limits 212 g/s. don't mean to sound doubtful but i've seen cars claiming 250 bhp on rollers but when went on what i call not happy rollers pull alot less than that.
Henk80
Well, i don't have a maf anymore so that limitation is out.
But to get to 250/260 bhp you need a lot of modifications and a very healthy turbo/engine.
