Did an hour or 2 tonight
Finially got the oil cooler mounted and sorted but i did forget the coolant so havent ran it yet :(
Also got my caliper bleed nipple sorted. Had to be cut out as it snapped a easyout on it haha
Lots to do little time to do it
:cry:Did half hour work tonight
Flush the brake fluid and replace it with the ATE racing fluid
Blead it all up on all 6 bleed nipples pumped the brake
Pour some antifreeze in
Reached for my keys to start it cant find my keys anywhere:cry:
Proper frustrated with it now
As i found my keys today work carried on
Oil cooler is all fitted
Also fitted and ran the wires for the oil temp gauge
Not sure how long it will last lol as its rather low
I have mounted the gauge just got to wire it up
And started mounting my seat frames
Ive also swop the leon fuel float for an ibiza one
So i have a spare ibiza 3bar pump if anyone needs one i have also a 4bar leon one of anyone requires one??
More tomoz and be back on the road :)
Goo progress bud. did you not think about buying a M10x1 t-piece from ebay to fit oil pressure and oil temp sensors up next to the filter.
also doesn't your sandwich plate have holes to fit sensors?
The 42 draft thing is good if you just want oil pressure. it doesn't work for the temp as it removes the probe from the flow :( i didn't think of that when ordering it.
So i've just ordered a T-piece to fit instead which should get the temp sender a lot closer to the oil so it should work.
got the t-piece which is m10x1 male with two female holes one m10 the other 1/8 npt (pressure sender thread for glowshift gauge).
Where did you get this from ? have you got a link by anychance, i have a oil temp and pressure that both need wiring up. Cheers
Shame the sensor sticks down like that on the shallow sumps, doesnt on standard sump so mines ok
Looking good though mate nearly there
How much for the Leon unit? Just trying to build up the last few bits before I take the car to get map set properly. Car isn't set up as advertised when I bought it and since its off the road ATM I want to get it the way it was meant to be.
Your car is looking spot on so much progress so quickly. Slightly jealous :p
