KatCowie's LCR 210 - Foxy :)
leons_ leon
BYE BYE GTI
Jan 2, 2010
577
Norwich
I have the S3 Cover and also have the Battery Cover waiting to fit. Im going to phone Jabba for the 5th and final time, and if don't get anywhere then giving up. Really want one tho :(
have a look at my thread with them fitted, have you got the bigger washer bottle?
KatCowie
OEM Lover
Jun 23, 2007
1,364
Inverurie, Aberdeenshire
Here you go Willie, not bad for a girl even if I do say so myself!! Chuffed to bits with myself.
Well today I decided to refurb my Brembos.
First of all I'd just like to say that I have never worked on calipers before, let alone Brembos. So this might not look that great to any of you lot, but to me, Im delighted.
Here's what they were like before.
So first of all I gave them a good clean, to remove brake dust ect using Quantum Brake and Clutch Cleaner. Then I picked off all the old lacquer that needed to come off, which I found very easy considering Im a girl with a lovely set of nails!
Then I wet sanded them using 1200 Wet and Dry Parer, which did the trick.
Then finally to put on fresh lacquer, where I did 3 coats leaving 30 minutes between each coat.
Once the last coat had been on 30 minutes I removed all protective paper and masking tape.
Here's the finished results.
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
thanks kat, mine isnt better than yours its just different. theses cars seem to be money pits as there is much you can do with them. also great effort on the brembos :D
