pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
right, ** finally decided that im going to go for looks over performance and im going to get myself a set of keskin kt1's, i loved them when i saw them on biggaz's cupra and i want some. Im going for 16's and having 7.5" on the front and 9" on the back. Not sure what offset i will need to achieve the best looks, here is what i can get, please advise:
(Front)
7.5x16 et20
7.5x16 et35
(Rear)
9x16 et15
9x16 et25
9x16 et30
will then be running 195/40/16 on the front and 215/40/16 on the back to get a safe stretched look. Just want advise on whats best before i shell out £700+
i run 7.5 et 35 all round need spacers on the front to clear the brakes. i will be going 9" on the back at some point.
Was gonna say ET35 will hit the calipers.
Was gonna reply to your pm mate, but may as well answer on here..
Out of the options you've listed
ET20 Front
ET25/30 Rear (depending on how sticky..outie you want them) ET25 will stick out further.
My Keskins are running ET30 on the rear and lines up perfectly with the arches.
Hope that helps.
Where you buying them from?
have you got any other pics of yours other than the ones you have previously posted? dubmeister is the cheapest i have found - any other suggestions?
just called 2modified, and im pleased you lot suggested him. Real nice bloke and couldnt help enough, he's done me a really good deal too. I will definately be using him again for anything else i need. Told him that i knew Ian from scn and then he knew exactly what wheels i wanted! awesome service.
he was telling me about you and how you wanted H10's or something?! I need to contact him asap, need to change my order, going for et30's front and back now, rather than et20's at the front.
ET30's will be more 'in' the arches though won't they? So you'll need 13mm spacers on the front anyway!
So either way you'll need spacers and i'd prefer to run a 3mm spacer than a 13mm spacer!
Correct me if i'm wrong!
