The manual says that KESSY deactivates when it detects too much activity on the handle (e.g. a branch hitting the handle in the wind).
For example, at a car wash, water can open and close my car. So I suspect that the same happens during rain/snow, but due to the lack of a key near the car, the car does not open, but the activity on the handle is registered - this causes its deactivation.
Wonder if you did a VCDS scan whether you would see anything. Something the earlier versions that Kessy don't do. My passenger side goes into sleep mode related the the battery voltage if the car isn't used. The electric tailgate ditto. Pull handle then it sorts itself out. Not often.
Not working for me to unlock at all now, it started with the cold weather but now it’s warmer and still doesn’t work.
A more urgent problem was that the car couldn’t lock left back door when it was under 5 centigrade, every time I passed 15km/h it tried to lock but immediately unlocked. When I left the car and locked one door was unlocked.
This is the second worst car I ever had and is on good way to be the worst.
