key coding with vagcom
urbanracer8
71
Bridgwater, Somerset
hi i have a mk3 ibiza cupra 20vt and this is how im spose to code keys;
"This procedure details how to match new keys to Immobilizer-equipped VW/Audi vehicles. As of 11 Mar. 2002, VW and Audi are providing 7-digit Secret Key Codes in place of the earlier 4-digit SKC's. Keys must be coded using the new 7-digit SKC (secret key code) method unless the owner still has the correct 4-digit code.
VW/Audi used to give out the SKC to vehicle owners but as of 2005 they no longer do. Unless you already have that information, then you will not be able to use these instructions - you will likely need to have your dealer perform this procedure.
Important Note: Unless you ALREADY have the SKC information for your vehicle and components then you will NOT be able to do any of the Immobilizer functions. Click this link for more information.
Procedure for matching keys to vehicles with Immobilizer in the Instrument Cluster:
(includes many 1999+ Golf/GTI/Jetta/New Beetle/Passat, also Audi)
[Select]
[17 - Instruments]
[Login - 11]
Enter zero followed by the 4-digit SKC.
For example, if your SKC is 1234, enter 01234.
[Do It!]
[Adaptation - 10]
Enter 21 in "Channel Number"
[Read]
The "Stored Value" is the number of keys currently matched.
Enter "new value" of 0
[Test]
[Save]
This clears out the old key-matchings.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys
[Test]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch ignition off and remove key
Insert next key to ignition and switch ignition on again
The warning light for the Immobilizer will light up for ~2 seconds, then go out
Repeat step 4 with each key until all keys have been matched.
is the skc code he 4 digit one, the key code or the immobliser code, as i have both in my PDI booklet cheers any help would be great
tony_tigger
immob code, your code is a 4 digit one and you will need to put a zero infront of it when inputting it into vagcom.
urbanracer8
71
right i have fitted my new clocks etc but it keeps saying the control wont accept the immo code, i put a 0 infornt and still nothing, because im fitting a 'new' (second hand) set of clocks will my immo code be differnt and will i have to get the code / login for that or should it be the same any help would be much appricated cheers
