got an intermittent problem with the key sometimes not going into the ignition barrell.
rac says its not a common problem ,but it is a known problem with vag .
the first pin in the barrell sticks in place and has to be moved with a small scredriver to allow key into the barrell-only happens sometimes. tried using spray etc ,but keeps happening-car still under warranty,but as its an intermittent problem ,it will probably be ok when i take it to garage-any ideas.
