Keys
gazzy-g
Hi
i wonder if someone can help me with this ive got a 2004 leon cupra R thats been de locked only leaving the boot lock ive bought a new central locking remote (the bit without the blade coz it comes in 2 halfs) does anyone know how to program them in to the car my original key is not working properly and has now completely packed in! managed to get into car through boot but as you can guess its not ideal!
Any help would be greatly appreciated!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Lee, that procedure is to match the *immobiliser* in the key to the immobiliser control in the car. Matching the remote central locking control is a separate process.
gazzy-g, will the new key start the car? I'm guessing it won't, in which case you need to do both the remote control matching and the immobiliser matching.
There are lots of threads about remote control matching, a search should pick up a few. There are at least two methods, I think. I expect VAG-com can be used to do this job. Need to do some research.
Done. Yes, it can.
marshyc
299
Huddersfield
Never heard of VAG-COM being able to synchronise a new remote. As Lee says, you need the door lock to do this.
No you don't.
You can pair the remote and the immobiliser with VAG-COM. You just need the SKC code to do the immobiliser chip.
I paired my remote using VAG-COM as I have de-locked my car so have no door lock to do it.
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
No you don't.
Could you detail how you do this?
I've always used VAG-Tacho to extract the immobiliser pin or SKC from the instrument cluster or immo box and then used the same program or VAG-COM to get the immobiliser to learn the new key. I've never seen it used to synchronise a remote transmitter to the central locking receiver though and would be interested to find out how its done.
marshyc
299
Huddersfield
All you need to know is right here Remote Matching
There are about 3 varying ways here but mine was done using the very last one to clear the existing keys then the first method to programme all keys I have.
Dave Roper
Does anybody have a rough cost of what it would cost to get the locks replaced on a SEAT Leon Ref Sport
I have a nasty feeling that my keys were left in the front door last night, and don't want to run the risk of waking up with nothing but tire marks in place of my car!!
marshyc
299
Huddersfield
This would be better asked in the mk2 section. But if they are anything like the mk1's you just need to get that key removed from the cars memory. It would still open the doors but wouldn't be able to start the engine.
p30esteves
try doing the following steps:
1-Lock the car.
2-(you need to stay near the car)
keep pressing the first button from your remote control and at the same time press the 2nd button twice.
3-keep pressing the 2nd button and at the same time press the first button twice.
Check if it works. I ve done the same in my old Ibiza and it worked.
Sorry for my english
