Evening all.
I'm a relative newb to leons, bought one a few months back.
It's only a 105bhp 2007 tdi sport (it's for the wife and she's nuts enough so she having anything mentally powerful)
She complained that it was making a noise last week, piped my head under the car and it sounded like it was blowing from the flexi pipe at the back of the engine, but only under higher revs.
So today I've taken it to the garage. It's one I trust, I've used them many times over the last 10 years with my modified pugs
So they tell me there's no exhaust issue, they checked the turbo for play, they also checked to see if the injectors were seated correctly (apparently this is a common issue?)
They have told me that they believe it's terminal either a holed piston or big end bearing.
It's still as noisy as ever.
It seems to run on 3 cylinders some times, lots of black smoke under heavy acceleration.
So my thoughts and any help/ideas would be appreciated
I can't see there being anything on the piston, this would surely show some sign in the block, diesel in the oil, low/high engine oil pressure? I'm going to get a compression test done on it to see.
Big end bearing, would this be noisy even at idle?
Maybe a knackered valve? But this would be noisy at all revs?
Maybe a failed injector? But again, wouldn't this be noisy at all revs?
If I have to change the engine then I will, but want to be 100% sure first. Was hoping somebody on here may have had this happen to them
Thanks in advance
Thanks in advance
