Knock, knock....
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Ok, car has a slightly annoying noise,
When breaking or driving at slow speed the car seems to be making a knocking noise,
- like a strut or bush thats away seems to come from the rear drivers side,
Anyone had any similar problems?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Whos there? :p
I think it must be your breaks/disc or one of your bolts seem abit loose. i would get that checked to be on the safe side
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
I had a problem like this on the front of my LCR, sounded like an anti roll bar broke.Drive forward in first gear clunk go back a bit and brake the same.took her in 2 seat and they said it was loose anti roll bar, so they swapped sum bolts and tightened it up.said it was all fine now noise now sir.i rolled forwards brakes and it made the noise wasnt happy.left it alone and then changed my front pads and disc's never heard it since.all been fine :D
dabossman
72
Surrey
Have had the same problem recentley. Stuck in traffic yesterday and noticed it then but coming from the front passenger side. Can you let me know if you get the problem sorted. Will have a play at tighting the bolts tomorrow and see what occurs.
Any1 else have had this problem and sorted it???????
ex_scoob
Had some slight knocking on my recently purchased 2005 LCR, turned out to be the front drop links. Had them replaced under warranty at the 20k service, problem solved :)
