Scottyleon
Hello,
I have a Leon 1.6 16v AZD engine, ran the vag-com on the car due to engine light coming on.
Control Module Part Number: 036 906 034 CP
Component and/or Version: MARELLI 4MV 3956
Software Coding: 00031
Work Shop Code: WSC 06441
Additional Info: VSSZZZ1MZ2R022417 SEZ7Z0A1252319
2 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-00 - -
17586 - Shareware Version. To Decode all DTCs
P1178 - 35-10 - Please Register/Activate - Intermittent
Also i have had a coolant temperature sensor fault.
When cold engine idles at 800rpm, when hot it falls to 600rpm. Sometimes it revs itself for 10 seconds between 600 and 800rpm.
The temp gauge takes about 10 minutes to reach 90 degrees and also did a weird thing when i was idling in traffic it dropped to 0 and when i moved it then sprung up instanly to 90 degrees again.
Any ideas?
2 Faults Found:
P1196 - 35-00 - -
Any ideas?
