Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
That would b better idea cheerz is there anywhere i can buy them
There 20mm i think maybe 15.. but it naturaly raises your sump a little more than that..
How can it raise it more than 15mm if the spacer are 15mm?![]()
must be the photo not showing the thickness.
Does this mean the engine 'tilts' backwards a little?
Because it brings the engine back at a tilt slightly.. therefors giving you that little bit more than the thickness of the spacer..
