x4d0w
37
recently I got the ABS light on, so I checked the error with vag-com and found more than that....
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00041
Shop #: WSC 06402
VCID: 24478AB5B40A6C618B-2586
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 13622
VCID: 3F8D25D93DAC2FB9F6-515E
VSSZZZ1MZ3R113693 SEZ7Z0C1960072
1 Fault Found:
17695 - Boost Pressure Control Valve (N249)
P1287 - 35-00 - Open Circuit
Readiness: 0000 0000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00257
Shop #: WSC 06402
VCID: 3A7B54CD268E0A91C1-4B00
Subsystem 1 - Part No: 1C0959802B
Component: A7 Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C0959801C
Component: A7 Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0009
1 Fault Found:
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
I cleared the errors, except for the ABS that was unable to clear, and after a journey of 70 miles, I checked again and got the errors on the top...
any help please
Please supply more car details i.e. Model engine and age :)
AMK is the engine code wich means 1.8t with 210bhp. so the LCR should be between 2000 and 2005.
but to be more specific a 2003 Seat Leon Cupra R, with engine code AMK and 210bhp
Ok cool first place I'd start is check the battery box fuses located in the lid if the battery box common cause of ABS light is a blown fuse here also home to fuse for climate control so could be a link here cheap fix so good place to start Seat dealer ships for some reason don't seem to stock this £3 or so fuse so try Vw it's a metal fuses that look like a spanner unless it's been used before there's normally a spare in the box hope this helps
it is not the fuse as it was the first thing I checked... and changed for a new one just to make sure
